Creo Parametric slow framerate over VPN
I am using Creo Parametric Release 5.0 and Datecode5.0.6.0
I have an issue when working remotely via VPN, where Creo will run smoothly for a period of time sometimes 5 minutes, sometimes 30, then suddenly its very laggy and far less responsive. The framerate drops dramatically and theres delay in being able to select anything using the mouse, or use the software in general. This affects both modelling and drawing.
The issue is instantly resolved by disconnecting from the VPN and reconnecting, without any need to restart the Creo software.
When on site, the issue does not occurr.
It seems to be a network issue of some sort - does anyone have any experience of this? Thanks
