How do you show Pipe Bend numbers that reflect the same location as what is outputted by the repeat region? I have followed the procedure in the help files and set default_pipe_bend_note to &bend_num:att_pipe_bend, but when I create my views the numbers do not show up with the bend notes. We are using Creo 4.0 and the application Creo Piping.
I figured it out. My config was not set to correct value. Should be as followed below:
hello,
since you've been using piping can you tell how to find maximum number of bends in a pipe?
thanks
