Creo Simulate 2.0 : interrupt-restart analysis & sections
ccantarelli
9-Granite
I have two questions about CREO Simulate (I am using the 2.0 version):
1) During the preprocessing of an assembly, I tried to create a cross section because it would have been very helpful to see more in details the mesh created in internal features of some parts, but unfortunately I could not. Is there a way to create it?
2) Is it possible to interrupt an analysis and restart it in a second moment from the point at which I interrupted it?
Thank you in advance for the help!
skunks
(To:ccantarelli)
1) no problem in wildfire 4 or 5, not possible in creo
2) no
regards
paul
skunks
(To:ccantarelli)
2) no
regards
paul
Please vote on the following enhacements that were filed a while back.
https://community.ptc.com/t5/Creo-Ideas/Add-ability-to-Turn-On-Off-existing-model-assembly-Cross/idi-p/468123
https://community.ptc.com/t5/Creo-Ideas/Add-pause-function-to-Simulate-analyses-and-design-studies-to/idi-p/460489
Hope this helps,
Don
Here are a few more enhancements that would be very usefull!
Add ability to Turn On/Off existing model/assembly Cross Sections along with creating them in Simulate / Mechanica
Add Ability to Component Repeat Placement to Include Duplicating Simulate Features Like Contacts, Ground Springs and Preloads (pattern also)!
Creo Parametric Simulate - Add Ability to Edit Model Feature Dimensions While in Simulate
Add ability to Creo Simulate Fasteners to Work With Tapped Hole Lead in Chamfers & Counter Bores
Creo Simulate / Mechanica - Add ability to use Fluid Cavities with displacement equations
Mechanism Clearance Check with Spatial Field Point Reporting (highlight on/in parts where clearance needs to be added & how much needs to be added)
Fix and Improve Creo Parametric Simulate (mechanica) Results Window Legend
Add abiltiy to record Analysis Measurement Dialog Box Text While using Mechanism Animate Capture to MPEG
Creo Simulate (Mechanica) Results - Persistent Legend Values Option
Remove Multiple Included Surfaces and or References at the Same Time
Improve and or Add Ability to Copy / Duplicate Load Sets, Loads, Constraints, Forces and Improve Naming and Function Consistency
Creo Simulate - Layer Control While Defining a Strain Vector Plot of Only Selected Surfaces and Abilty to display vectors on only surfaces in dirrect view.
Add Automatic Functionality to Convert Assumed References to Permanent  References for Features Displaced by Other Features
When Copying and Pasting Text Add Ability to Convert Pasted Text To All Capitalization
Creo Parametric Simulate - Delete Multiple Analysis
Mechanica / Simulate Edit Load Set Description
Add Ability to Suppress Surface Regions in Creo Parametric Simulate
Reorder a component's position in the model tree while in insert mode to a location in between suppressed components
Add ability to Identify Mechanism Constraints that could not be Satisfied
Improve Repeat Placement of Component with Mechanism Placement Constraints
Add Ability to Creo Parametric Simulate to Copy Components and or Sub Assemblies and related Simulation Features from one Assembly to Another Assembly
Batch Mechanism Analysis - Like Mechanica/Simulate
Allow Creation and Editing of Simplified Reps and Changing States While in Creo Simulate / Mechanica
Create Simulate Results Window Templates from Design Study related to Assembly Analysis with multiple load cases and windows
Add Ability to Select Creo Simulate Parametric Features in a Model or Assembly and Right Click to Locate or Highlight in Model Tree
Creo Parametric Simulate - Design Analysis Flexible Dimensions (model dimension variation driven from analysis) and Specify Different Materials
Isolate Component(s) By Hiding ALL Non-Selected Components for Temporary Effect (No Layers or Reps)
Add Ability to Creo Simulate to Copy Simulation Features From One Part or Assembly to Another Part or Assembly
Allow Adding Multiple Motion Axis Constraints to Snapshot in Mechanism and Highlight Display of Joint on Screen When Selected under Constraints Tab
Add Ability to Change Table Row Height While Entering in Text and Change Cells without unselecting the table
Add Flexibility to Drawing View(s) to Allow Parameters and or Dimensions to be Varied to Allow for Alternate Installed States without using Family Tables
Show Dimensions by View when selecting multiple features in the model tree of a drawing
Add Ability to Select a Component in Creo Parametric Simulate and Show Only All of the Dependent Simulate Features
Creo Simulate - Allow you to select a Model or Sub Assembly in the Main Window and Right Click to Open It.
Round Feature Enhancement - Allow to Extend Ends x Distance on Both Ends When Round Create as Surface Type
Prevent Snapshot Constraints from Supressing when a Assembly with a (6DOF) Mechanism Joint has been Rotated or Reassembled
Regeneration Manager Open Failed Model on Right Click
Add pause function to Simulate analyses and design studies to allow analysis to be moved to another workstation to continue running
Surface Regions Improvements - Creo Simulate Option to Split into Segments
Allow double click edit of dimension or tolerance value in drawing
Improve copying of datum points set as datum targets from one model to another model
Enhancement Requests for Creo Simulate 3.0 or Newer (Rounds)
Un-Delete / Restore a Mechanism Analysis that was deleted by accident
Don Anderson
No time Like the Present!
skunks
(To:danderson-3)
a cross section in Wildfire 4.0:
danderson
(To:skunks)
Were you able to create the cross section in Wildfire 4 while in Mechanica or was it just activated/turned on?
A couple of issues I run into are:
-Not being able to create a Section Feature while in Simulate that can also be used in normal assembly or part mode.
-While creating Simulate features, if you cancel out of creating a feature Creo will turn off the active cross section.
I will have to go back to my wildfire 4 M220 installation and take a closer look.
