Quick intro - Hello, Kurt here, recently laid off from my Solidworks position - on SW since '96. Have an interview next week for a position using Creo. Downloaded 30 day free trial and am going thru tutorials, specifically the one above: Creating extrusions using sketches.
Directions say to RMB sketch1 and choose unhide, but unhide is not available. I would wager that i am in some other mode or command that disallows this command but i've exited and restarted, still to no avail.
Link below is to the tutorial (item 5 and attachment is my current-state screen.
Any assistance would be appreciated.
Kurt
Right click on the greyed out Sketch 1 above Extrude 1 feature. You won't get the Show/Hide function on an embedded sketch.
wow, thank you...I didn't even see it for looking so hard at the embedded one. Care to tell me why there is a sketch 1 embedded (like in SW) but also one above it? What the theory is ...or will i find that out thru general use?
Kurt
So that you only have an embedded sketch start the Extrude/Revolve command first and this will create the sketch embedded. If you want to use a sketch in multiple features you can do that with a non-embedded sketch.
