Hello everyone.
I am opening CEDM models in Creo Parametric. When calculating the mass properties of a mixed assembly (composed of CEDM and Creo Parametric files) I noticed that the Modeling files have the mass at 0 (PRO_MP_MASS). Is there a way to calculate it? All this without modifying the original Modeling file.
Thanks to all.
Bye
Marco
If the Creo files don't have a density assigned they will return a calculated mass of zero. You'd need to assign a density or directly assign a mass to each of the offending components.
I don't know what CEDM means.
CEDM is Creo Elements Direct Modeling, the old HP ME30 package.
Hi @MP_10756090,
Anurag
