Creo View 1.0 Measurements
ptc-680841
It seems I am only able to select a component or a surface when taking a Distance measurement (plane to plane) and can not select an edge, vertex, centerpoint, etc. Has anyone else noticed this? Thanks for the sanity check. Andy B.
1 REPLY 1
This problem was related to the model. I can measure and select edges or vertex or arc center, etc on other models. Must be how it was published or that it is an older publish format.
Sorry for the false alarm.
Andy
