I'm still on Creo View 3.1 where the save as 3d options are step, iges, VRML and DXF. It appears from some PTC cases, that in 4.1 there is Save as JT capability. Does anybody know if the capability is there in the MCAD license pack?
Bill,
The JT option is not available in 4.1. Below is an image from Creo View 4.1 F000.
We are moving forward with Creo View 4.1 because it now has the capability to compare PDF's even though we publish to .plt for drawing compare.
Bill,
