When I try to view *.pdf.pvz files (downloaded from a Windchill PLM server) using Creo View Express 3.1, I get the following error:
"This computer must be connected to the network"
"Connect this computer to the network and then try opening the document again."
Here is my computer information:
I also tried a Windows 7 Pro PC with the same Creo View Express 3.1 (32 bit)
This is a show stopper, so any help to resolve this issue would be appreciated.
Thank you
AJ
So you are using Creo View Express instead of Creo View Lite (Standard, MCAD, ECAD) to communicate with a Windchill PLM system? (Also, just to clarity, is the file actually a PDF or PVZ?)
They are .pdf.pvz files. I think that means the PDFs are embedded in the PVZ container files.
Using Creo View Express
