Firstly, apologies if this is the wrong place - wasn't sure whether this should be Creo or Windchill. Moderators, please move it if appropriate.
Is there a way in Creo View (Lite) to make it remember (or change) your PDF viewer settings?
Specifically, I want to be using Hand Tool (which I have to change every time via RMB), and with the view set to Zoom All (which again, requires a click once the viewable has loaded, otherwise I can't see the bottom 15% of the drawing).
Not PDF related, but if I could have the ribbon collapsed by default that would be lovely too...
Creo View Lite, 3.1, F000 build 42.
Thanks for any input!
