Since we went from Pro/INTRALINK 10.2 from version 9.1 Creo View opens embedded in IE instead of stand alone. Is there an option to launch Creo View as a stand alone program as it used to function? I've been looking at the Creo View options & Windchill preferences with no luck.
Mark,
Creo View as a stand alone program when you launch it from your desktop or start menu on your computer. It launches embedded in IE because it needs to talk back to Windchill on in your case Pro/INTRALINK 10.2.
Since you installed it from Pro/INTRALINK it is on your computer somewhere and can manually be launched from that location.
Thanks. I get that part it was just nice when it ran as its own non-embedded program (still tied to Windchill of course) because you could see in the banner if you had MCAD vs. Standard etc. Functionally its the same.
