When exporting a 2D creo drawing to PDF, the microsoft word objects that are inserted are not selectable text in the final PDF. Is there a setting so that inserted objects are selectable/highlightable in the resulting PDF?
Inserting an object in this way, but it seems to come into the 2D drawing as an image and not text/table.
The objects thus inserted come in as an OLE object. Meaning they remain as a Native file (Word, Excel etc). For Notes one may keep Standard Notes for Drawing in a Text file and ask Creo to read from the file or copy--> Paste those texts. Drawings converted to PDF using above would have 'Selectable Text'.
For Spreadsheets.... Create a Creo Table.
So there is no way to save a 2D drawing to PDF where OLE objects are selectable objects? Or there is no setting in Creo that makes OLE objects selectable text before saving?
Check out these settings.
| Setting Name | Description | Value | Default Value |
| intf2d_out_acad_mtext | Create a single MTEXT entity for multi-line text notes when is set to YES. | yes, no | yes |
| intf2d_out_acad_norm_lead_block | Yes - Multiple normal leader annotations are exported to DWG and DXF file formats as blocks. No - Multiple normal leader annotations are exported to DWG and DXF file formats as separate entities. | yes, no | yes |
| intf2d_out_acad_ole_as_image | Controls OLE export to DXF/DWG. Yes - exports OLE objects as DXF/DWG IMAGEs. No - exports OLE objects as separate entities. | yes, no | yes |
| intf2d_out_acad_splines | Controls whether splines are converted to corresponding DXF/DWG entities or exported as polylines. | as_spline, as_polyline | as_spline |
| intf2d_out_acad_sym_block_name | Determines whether symbol definition or symbols instance names are used as block names in DXF/DWG export when symbols are mapped to blocks. SYM_DEF - symbol definition names are used, SYM_INST - symbol instance names are used. | sym_def, sym_inst | sym_def |
| intf2d_out_acad_text_align | As_is - Exports notes to DXF/DWG with their original alignment values. Fit - Exports notes with FIT alignment. | as_is, fit | as_is |
Hello, and thanks for the reply
I only had time to try a couple of those suggested settings. I thought "intf2d_out_acad_ole_as_image" would be the one for sure but it hasnt worked yet. I will try the remaining suggestions on your list and let you know.
Please do let us know What Resolved and How resolved, for our benefit too.
Hi @CB_11916535,
Anurag
