Creo parametric 7.02 Render studio
ptc-4610461
3-Newcomer
Hi, I am a secondary teacher I am using Creo parametric 7.02 and there seems to be an issue in the render studio. When editing a material I alter it in terms of rotation or scale and then when it’s rendered it changes and isn’t what I have set up. Has a anyone else had that issue or can you give me any advice.
5 REPLIES 5
please attach pictures showing your actions.
Martin Hanák
Good morning
sorry I have been off work for a while. Before the October break the bump map was moving 90 degrees around now the texture depth will not change no matter what settings we use.
1.] Creo 7.0.2.0 is not installed on my PC
2.] Render Studio is not installed on my PC
I tested bump rotation in Creo 7.0.5.0. Please replay attached video.
If you can record video on your PC to show the problem. If you upload such video, I will install Creo 7.0.2.0 + Render Studio and try reproducing the problem.
Martin Hanák
Thank you for this, Yes that what we were doing to rotate the bump map but then when we go into render studio it doesn't stay in the direction it reverts back to the original orientation.
Creo 7.0.2.0 works well on my PC. See uploaded video. Unfortunately I have no idea what is the root of your problem. Maybe graphics drivers were updated and their current version is not compatible with Creo.
Martin Hanák
