Is there a way to set Croe2 to step through the required references automatically? I would like to eliminate the need to click on the 2. SURFACE (in the dialog box) then the part surface and back again to the dialog for 3. SURFACE then a part surface. Its alot of back and forth. any ideas?
Well I created a Mapkey that does what I want so disregard ![]()
