Crosshatch on model to show on drawing (or other technique)
kevsterini
I am design some fiber optic arrays and the drawings will have views showing the end of the fibers (basically a bunch of circles in an array/pattern). To indicate which direction the light is going through the fiber some will have crosshatching and some will not. The only way I've found to do this is to make the circular shapes in the model then in drawing mode 'use edge' and in order to make the circles selectable for crosshatching (filling). The problem is we're changing these things all the time and the circles do not update with the model even after I do a relate view). Any suggestions on how to do crosshatched circles on a drawing?
0 REPLIES 0
