Curiosity where did the commands go???
rrich
2-Guest
I recently changed jobs and at my new position I did not bring along my old
config files. Not a huge problem as I do not use very many custom items.
However one I did use was for changing the number of digits in drawings
either dimensions or detail scale or other such things. I had suffered for
a while changing dimensions by high lighting, properties, type digit and
applying. However I could not find where or how to do that to a detail
scale note in WF4. So I made a few inquiries to some past coworkers and go
my old config file. After reviewing the mapkey I used for digit changing,
it spawned these questions?
First here is the mapkey if you replace the 1's with 2 or other number you
will get that many digits after the decimal. How to use - click the note or
dimension (can use control and multi select) then type nd1 and all will
change to 1 digit past the decimal.
mapkey nd1 #Done/Return;#Modify;#Num Digits;1
Now for my questions.
1: #Modify --- Where is the modify menu or where did it go? - I cannot
find it anywhere.
Here's one
Enter text into a table
mapkey tet #Done/Return;#Table;#Enter Text;
This brings up a hidden menu that also offers copy to copy text from one
cell to another. I use these a lot for Rev and Title block info.
Bob Frindt
Sr. Designer
Parker Hannifin Corporation
Parker Aerospace
Gas Turbine Fuel Systems Division
9200 Tyler Boulevard
Mentor, OH 44060 USA
direct (440) 954-8159
cell: (216) 990-8711
fax: (440) 954-8111
www.parker.com
Ron Rich <->
12/08/2009 11:52 AM
Please respond to
Ron Rich <->
To
cc
Subject
[proecad] - Curiosity where did the commands go???
old config files. Not a huge problem as I do not use very many custom
items. However one I did use was for changing the number of digits in
drawings either dimensions or detail scale or other such things. I had
suffered for a while changing dimensions by high lighting, properties,
type digit and applying. However I could not find where or how to do
that to a detail scale note in WF4. So I made a few inquiries to some
past coworkers and go my old config file. After reviewing the mapkey I
used for digit changing, it spawned these questions?
First here is the mapkey if you replace the 1?s with 2 or other number you
will get that many digits after the decimal. How to use ? click the note
or dimension (can use control and multi select) then type nd1 and all will
1: #Modify --- Where is the modify menu or where did it go? ? I
cannot find it anywhere.
Yeah, I was aware of that, and I should have included it in my response. I
use it because it saves a click when copying into multiple cells. Using
the menus, once the "copy" item is selected. you can click into cell after
cell and not have to hit Ctrl+C every time. (also an old habit from the
UNIX days when Ctrl+C was not an option).
Not much of a time saver, I know, but this was more directed at Ron's
query about hidden menus
Bob Frindt
Sr. Designer
Parker Aerospace
