Curve from Equation inside datum graph?
Does anyone know if it is possible to, inside of creating a datum graph, put a "curve from equation"?
When I go to datum graph, the option for datum "curves" and then "curve from equation" is not available.
I would like to create a "datum graph" with a "curve from equation" so that I could offset from a spline, based on an equation.
I have a part shaped with a spline curve. I would like to pre-stress it the way a beam would bend (using beam bending equations) so that when it is counter pre-stressed, it deflects in a way to form the spline perfectly, if that makes sense.
If there is a way to control curves inside of "datum graph" using equations in another way, that would work as well.
I hope this makes sense and thanks in advance!
