Community Tip - If community subscription notifications are filling up your inbox you can set up a daily digest and get all your notifications in a single email.
X
I need to use a custom trajectory to mill a scroll pattern but the tool I am using needs to have a ramp angle. I am using a step depth of 2. mm per pass. The last cut is 25mm deep. There is not an open section for the tool to feed down at 90 degrees, it has to ramp in above the cut. How do I add a ramp angle to this sequence?
Byron Taylor Coordinator/Programmer
Danfoss commercial Compressors One Scroll Drive Arkadelphia, AR 71923 E-mail: byron.taylor@scrolltech.com Tel.:870-246-0750 This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
What I have done is in customize > build cut> approach (plunge, tangent, or normal)> click on the offset and then on Toolpath. This will bring up a dialog box to click which axis you want to offset.
