All
I'm having some difficulty saving changes that I make to thecreo_parametric_admin_customization.ui file for our users.
I start a clean session of Creo 2 where the only ui file used is the one stored in the 'text' folder of the Creo 2 install location, i.e. there is no ui file in either my default working directory or in the 'C:\Users\Neal.Hanratty\AppData\Roaming\PTC\ProENGINEER\Wildfire\.wf\.Settings' folder
If I edit the ribbon interface, add a couple of icons etc. and then export the new ui file to the Creo 2 install\text folder it's size drops from 45 kb to 2-3 kb and all of my original modifications are no longer there.
Any body come across this? Is this a bug or am I doing something wrong?
Ideally I would just like to have each user have acreo_parametric_admin_customization.ui in their text folder and nothing else. Is this possible now with Creo?
We don't use Windchill but do use a bespoke PLM solution.
Any advice would be much appreciated.
Neal
Thanks to all for your suggestions...ended up it was a quirk with our bespoke PLM system.
But one further question...I assume once a .ui file has been created on a PC it can be copied to other PCs and should work in the same way?
