Cutting tool parameters
cncwhiz
2-Explorer
I am looking for a list of the cutting tool parameters for milling. I for the most part use "cutter_diam, tip_offset, Length". I have an old manufacturing book somewhere that lists all the other parameters but it is hiding from me. Does someone out there have these parameters that they will share?
4 REPLIES 4
I don't have a full list but I use:
CUTTER_DIAM
LENGTH
NUM_OF_TEETH
FLUTE_LENGTH
CORNER_RADIUS
TOOL_COMMENT
TOOL_TYPE
If you forget the parameters you can always save the parameter tool, and
look at file with text editor or browser and see all the tool parameter for
specific tools
- <mfgsetupdocument>
<doctype>PRO_NC_CUTTING_TOOL_SETUP</doctype>
<doctitle>Cutting Tool Information</doctitle>
<datetime>2011-06-22T13:30:18</datetime>
<applicationinfo appname="Pro/ENGINEER" language="usascii" appversion="M080"&lt;br"/>/>
- <toolingsetup>
- <tool id="T0001" type="MILLING" refxmlid="encref_1">
<attr name="UseOutline" value="false" datatype="boolean"/>
<attr name="ProLibraryTool" value="false" datatype="boolean"/>
<attr name="SketchTool" value="false" datatype="boolean"/>
<attr name="ToolByRef" value="false" datatype="boolean"/>
<mfgparam name="LENGTH_UNITS" value="INCH"/>
<mfgparam name="CUTTER_DIAM" value="0.5"/>
<mfgparam name="CORNER_RADIUS" value="0.06"/>
<mfgparam name="SIDE_ANGLE" value="5"/>
<mfgparam name="LENGTH" value="3"/>
<mfgparam name="NUM_OF_TEETH" value="4"/>
<mfgparam name="TOOL_MATERIAL" value="CARBIDE"/>
<mfgparam name="GAUGE_X_LENGTH" value="-"/>
<mfgparam name="GAUGE_Z_LENGTH" value="-"/>
<mfgparam name="COMP_OVERSIZE" value="-"/>
<mfgparam name="TOOL_LONG_FLAG" value="NO"/>
<mfgparam name="HOLDER_DIA" value="1.25"/>
<mfgparam name="HOLDER_LEN" value="1"/>
<mfgparam name="COOLANT_OPTION" value="OFF"/>
<mfgparam name="COOLANT_PRESSURE" value="NONE"/>
<mfgparam name="SPINDLE_SENSE" value="CW"/>
<mfgparam name="FLUTE_LENGTH" value="0.5"/>
<mfgparam name="TOOL_COMMENT" value="MSC#:"/>
- <toolsetuponworkcell>
- <offsetdatacollection>
<offsetdata tip="1" comment="MSC#:" offsetz="0.000000" register="1"/>
</offsetdatacollection>
</toolsetuponworkcell>
</tool>
</toolingsetup>
</mfgsetupdocument>
Dale
The xml table listed below is used since wf4. If you have wf3 the tools are defined using tpm files.
David Brainsky
Certified PTC Instructor
Chula Vista, Ca. 91910
Sorry to mislead all. I should have stated WF2 for the tpm files not WF3
David Brainsky
