I am working with a geometry that uses a datum curve from an equation.
Certain parameters can be changed by the user in order to manipulate the curve.
The issue I am having:
Based on the parameters, two relations define numbers A1 and A2 which can limit the curve (see pic.).
Unfortunately, I could not make the curve's limits update when the parameters (and subsequently the relations) are set by the user.
It only worked like this until now:
Is there any way to make this work without having to manually insert A1 and A2 each time?
Thanks!
I would suggest trying this:
* Set limits to 0.0 - 1.0, create "w" parameter to replace t and use relation parameters to set limits.
w = ( t + A1 ) + ( t * ( A2 - A1 ) )
x = 4 * cos ( w * 360 )
y = 4 * sin ( w * 360 )
z = w
This spiral equation worked well for me.
I would first try to enter the names of the parameters controlling the evaluation limits instead of those values. If that doesn't work then enter 0 and 1 and change the equation to use "T+A1" and "*(A2-A1)" to change the limits inside the equation. ( I think those are right - A1 sets the lower level for evaluation and A2-A1 sets the span of the evaluation.) If you post the equations it may help to see the effect.
Thanks @dschenken and @kdirth!
Hadn't thought of an extra variable.
So the following worked (D_CNTCT is the diameter of a circle and I wanted my logarithmic spiral to be limited around this circle)
A1= ln(D_CNTCT-10)/EXP_FCTR
A2= ln(D_CNTCT+10)/EXP_FCTR
w=A1+t*(A2-A1)
r = exp(EXP_FCTR*w)
theta = 360*w
z=0
z = w
Allowing relations in the limits fields could be a good idea to suggest.
