Datum Placement on Diameter
akelly
I've got two drawings with the same kind of dimension: diameter with a GTOL that is also a datum
To keep the dimension line from crossing the datum symbol, I inserted a couple of blank lines in the dimension properties. The "GOOD" drawing looks fine.
I repeated this in another drawing, but it is putting the datum symbol below the blank lines instead of attached to the feature control frame.
I exported the drawing properties of both and did a file compare ... they match.
I can't figure out why I can't get the "BAD" drawing to look like the "GOOD".
0 REPLIES 0
