Datum tag in generic part (family table)
sundoopi
8-Gravel
Hello everyone,
I used family table to create two parts. In the generic part datum A was created on a plane. But this plane (feature) is suppressed in the instance part, so one error occored. But the change and this datum A is needed in the instance part. Could you please tell me how to do it with MBD? Thanks in advance.
Br
Sun
Well, I "faked it" by attaching the datum tag to a surface:
Generic:
instance:
This construction fill surface was then hidden away.  You should also add some relations so it follows the relevant feature sizes.
9 REPLIES 9
tbraxton
22-Sapphire I
(To:sundoopi)
The Creo error with the annotation is resolved in this model for the generic and the instance. The annotation plane A is present in the instance without error.I have questions  about documenting a plane on a part that can not be established on the part for inspection but I suppose that is a separate issue.
Involute Development, LLC
Consulting Engineers
You have to redefine the plane you are using for Datum A so it is not suppressed in the instance. This kind of thing happens a lot with section views, etc. You have to be careful when defining features to avoid using references that will be suppressed in instances from a family table. Check your references and replace them.
tbraxton
22-Sapphire I
(To:sundoopi)
This would be an option to establish a datum reference plane in the context of your family table.
Hello  tbraxton,
yes, you are right. But this option is not suitable for our part.
But thanks too.
Br
Sun
Patriot_1776
(To:sundoopi)
This is one of the MANY reasons why I do not use MBD at ALL, and put ALL my GD&T info on the dwg.  This way I can easily change anything I want, and not affect anything else.  Also, this eliminates having problems with duplicate datum names at both the part and assembly level (as for a weldment, etc.).
@sundoopi , are you trying to accomplish this:
generic:
instance:
yes!
Generic:
instance:
Hello all,
thanks for your answers. It looks, that we have to trick the message center with a "faked datum plane".
I found in Creo 6 or higher versions we can have a besser solution:
(952) Improved Handling Between Parent and Child for Annotations in Model-Based Definition | Creo 6.0 - YouTube
Best regards
Sun
