Deactivate a feature Id
ddhini
I have a Model file .In my model file d21 is a name of a parameter. 22971 is the name of a feature.I want to display the feature id 22971 when d21==168
So i write a program in my relation
if d21==168
22971 = False
endif
But this is not working.Please help me to Solve my issue.
4 REPLIES 4
MartinHanak
(To:ddhini)
you can suppress specific feature using Pro/PROGRAM functionality. Look into Creo Help.
MH
Martin Hanák
ddhini
(To:ddhini)
Can you please Explain with simple code ? Thanks in advance
MartinHanak
(To:ddhini)
kai-2
7-Bedrock
(To:ddhini)
Please refer to the content provided by Martin Hanak.
Here is a simple example.I want to display extrude 2 (Feat ID=76 ) when d3 value = 168.
Refer to the following steps:
1. Find the Feat ID in model tree (id = 76)
2. Create a new Parameter (Real number ,TEST, Initial value =70.0 ) and add a relation code (D3=TEST)
Hint:"In my model file d21 is a name of a parameter" => You can not use d21 directly, d21 is the name
of dimension.
3. Open Pro/program and find id =76
4. Add an if / end if statement in the program (blue font)
IF TEST == 168    <= Add here
ADD FEATURE (initial number 9)
INTERNAL FEATURE ID  76
PARENTS = 1(#1) 3(#2) 56(#8)
PROTRUSION: Extrude
  NO.    ELEMENT NAME      INFO
  1      Feature Name      Defined
  2      Extrude Feat type  Solid
  3      Material          Add
  4      Section            Defined
  4.1    Setup Plane        Defined
  4.1.1  Sketching Plane    Surf:F8(EXTRUDE_1)
  4.1.2  View Direction    Side 1
  4.1.3  Orientation        Right
  4.1.4  Reference          SIDE:F1(DATUM PLANE)
  4.2    Sketch            Defined
  5      Feature Form      Solid
  6      Direction          Side 2
  7      Depth              Defined
  7.1    Side One          Defined
  7.1.1  Side One Depth    None
  7.2    Side Two          Defined
  7.2.1  Side Two Depth    Variable
  7.2.2  Value              70.2103
SECTION NAME = Section 1
FEATURE'S DIMENSIONS:
d3 = (Displayed:) 70.2103
      (  Stored:) 70.2103 ( 0.0001, -0.0001 )
d4 = (Displayed:) 40.8952 Dia (weak)
      (  Stored:) 40.89523802445 ( 0.0001, -0.0001 )
END ADD
END IF            <= Add here
5. Save and try it. ( display the feature when test = 168)
