Default Room Layout & Colors
tgiauque
Folks,
Like many of you, I use Pro/E to generate a lot of pretty pictures for presentations, to accommodate marketing requests, and so on. Rather than doing a straight screen dump of a model, I like to render the screen first in order to get nicer-looking pictures. Unfortunately, rendering the screen throws my beautiful part into a room that appears to be some kind of darkened torture chamber.
I would like to know if it is possible to create a new "default" room layout and color scheme. I do this sort of thing fairly often, and it's a real pain to redefine the room every time. I don't like the dark colors of the default Pro/E room, I want one that's all white walls and ceiling.
Anyone know how to redefine the default room permanently? I'm using WF5.
Tim
Tim Giauque
Project Engineer II
FN Manufacturing, LLC
Phone (803) 736-0522 x383
Fax (803) 865-3543
6 REPLIES 6
Tim,
You want to explore scenes and the graphics library that is available
for download from ptc.com.
Scenes will enable you to setup everything about the room, ie lights,
properties, decals, textures etc etc etc. This means that the whole
environment can be setup in seconds.
Regards
Iain
Lewis,
Thank you for your reply. I have already created a white wall color that can be applied to my room pretty quickly. However, I want to not have to do this every time I go to render an image. Is there a way to redefine the default room design?
Tim
Tim,
If you set the default scene in the template that you use to generate
your part then there is no need to set it later on. Ie in the template;
Regards
Iain
PaulSagar
(To:tgiauque)
Tim
You can also save the scene as a new file and then use the following
config option
default_scene_filename - set to the saved scene
Paul
~hey Iain,
Where in ptc.com can we get these? (can't seem to find them...)
tia
_mark
Mark,
Goto www.ptc.com > Support > Order or download Software > ProENGINEER >
ProENGINEER Wildfire 4.0 Graphics Library .
Regards
Iain
