Default Tolerance Display
AraviK1
Hi folks,
After setting of tolerances , If I click OK. It will not displaying Tolerances on dimensioning.
For that i need to do manually everytime by using @++0.5@#@--0.25@#. Its very difficult to do for more dimensions. Its time taking process.
Can anyone help on this to fix directly on dimension without any manual inputs.
AraviK
5 REPLIES 5
Dale_Rosema
(To:AraviK1)
Check out this discussion, I think that will answer your questions:
http://communities.ptc.com/message/191103#191103
Thanks, Dale
Thanks Dale.
Dale_Rosema
(To:AraviK1)
If that solved you issue, you may want to mark it so that those who find this discussion later will know that you found your solution.
Not yet followed Dale your given link. once check with that, i will reply that sure.
AraviK
You may find some tips to follow in https://www.youtube.com/watch?v=B2O9pb-Y_ys
hope its useful.
