I am using Creo 9.0.8.0 and in the process of obsoleting some parts.
I delete a couple of patterns of parts (stacked on a skid), but the quantity dimension is left behind (orphaned?). Is this a bug?
Before deletion (I hadn't saved, so I exited and started over)
After deletion
Thanks, Dale
FYI, The Delete option was used and not Delete Pattern and then Delete object that was patterned.
