Dialog box
emathivanan
2-Explorer
Dialog box
when im doing some of the operations in assembly i cant press OK because of my dialog box going out of the screen.. IS there any ways to control. im using creo 2.0
Not sure what operations you are talking about but usually middle button clicking is the same thing as clicking the "OK" check box.
dgschaefer
(To:Chris3)
Using the MMB for "OK" is not necessarily reliable.  It frequently means OK, but often means cancel, new or does nothing. I think it should be consistent, and [shameless plug alert] created a product idea for that.
Elango Mathivanan - Can you drag the window back on screen? Do you perhaps have your screen resolution set too low?
LinkedIn
