I will try posting this elsewhere also, but just wondered. Does anyone have a comprehensive list of all config options? Used to have one years ago, but cannot place it now. I am sure there have been additions over the years as well with the new revisions. Thanks !
They are on PTC's website.
WF4: http://www.ptc.com/WCMS/files/65779/en/WF4.0_012408_configoptions.pdf
WF5: http://www.ptc.com/WCMS/files/99859/en/WF5M060configoptions.pdf
Not sure if you need specific login access to get to the docs. If you do, let me know and I will see if I can upload them on to PlanetPTC
Paul,
I know you posted this back in 2010, but it is just what I was looking for today. The config options for WF4.0.
I was able to get to this without any problems.
Dennis
FYI, Creo does this by default now. It seems to re-evaluate the sketch each time you click the "add dimension" button. Once you add a proper centerline(*), it changes your radial intent dimensions to diameters. It does this with angles as well which is a nice improvement from 2000i.
(*) I didn't know we had dedicated centerlines for rotation in Creo (2000i didn't have this). Drove me nuts! ...but I understand why this was needed as you could only use one centerline in 2000i "successfully" in rotations.
With effect from WF5, PTC has introduced "Geometry Centerline". Sketch the geometry cl first and then sketch the profile for revolve protrusion. The dimensions are then taken as Diameter Diamensions.
I know this is an old post. I am still posting it if it helps somebody.
