I want different background color for my drawing and part model environment please suggest how to do so.
e.g I have blue background for Part model environment and I want back background for drawing environment.
Thanks in Advance
You can go in File --> Options --> System Colors. There you can chose the appropriate background colors and geometry colors. Save this setting as system color file. (with .scl extn). Place this file in your default startup directory.
Color settings will get automatilly applied whenever you launch Creo / Pro/E
Check steps and information at https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS45780
