We have done a number of drawings for a project before we realized that the dimensions were set to inches. Is there a way to convert all these drawings so they display in mm.
I think you will have to switch units in every model and every drawing.
Model:
Click File > Prepare > Model Properties > change in Units row > activate appropriate units in Units Manager dialog box
Drawing:
Click File > Prepare > Drawing Properties > change in Deatil Options row > load drawing option file prepared for "millimeters" (for example change drawing_units option value)
MH
Actually, I think there is a way to do this...
In the drawing, go to File > Prepare > Model Properties > Detail Options [change].
Set dual_dimensioning to secondary and dual_secondary_units to mm.
Give that a shot...
Hi David,
Does any of the reply on post help you?
Hi Mahesh
I have asked the Creo3 Teacher concerned to try the solutions with the students and let me know the result. I will report back when I
have a response.
