Dimensional Symbol Pen_thickness thick than all in Dwg
Yogesh.T
How to keep the symbols also consistent with other Pen_width?
SEE IMAGE Please. Thanks in advance with your solution. It looks so odd on a print.
There always something crazy challenge in Creo!
3 REPLIES 3
Dale_Rosema
(To:Yogesh.T)
Check this thread to see if it is the same issue that you are experiencing:
https://community.ptc.com/t5/3D-Part-Assembly-Design/Dimension-Text-Symbols-Pallet-changed/m-p/1050864#M142464
look at symbol_font detail option. It is defined in drawing and also in drawing model. In both locations it is necessary to use the same value.
Note: Test all symbol_font detail option values and set the one suitable for you.
Martin Hanák
Yogesh.T
(To:MartinHanak)
Ohh..okay trying it now and need info on what should i browse for? i mean what file? 🙂 Image attached.
I want the symbol same as text style.
Thanks.
