Hi all,
I have created a pattern of holes on the flange and while i dimension the hole in the drawing it is showing to the hole1 feature(the generic or partent hole) but i want the dimension of the hole to a hole member other than the generic hole, i have tried it using note and @d but is there any option other than using the note option.
Thanks & Regards,
Naveen Kumar Gongu.
Naveen,
This is duplicate of your earlier thread http://communities.ptc.com/message/241132#241132
Naveen,
