Software version: Cero 9
Noticed a problem when standard steel metal appearance is assigned to a material. When shading with reflections from the view ribbon is used (CTR+1) the appearance is as it should be, however when shading with edges (CTR+2) is used there is no colour assigned to the appearance it seems to revert to a random colour. In my case I have a couple of appearances assigned to a couple of materials and have been cycling through them. The last materials appearance that has been used is what seems to default on the metal appearance when shading display style is selected. Is this a bug or am I doing something wrong?
please publish picture of 2 display statuses and pictures of appearance definition.
You can also upload test model with appearance assigned (pack it into zip file before upload).
