Displaying Analysis Feature in Sheetmetal, Displaying on Print?
Pieface
I have never encountered this situation before.  I am unable to display the values for Saved Analysis Features in a drawing.  In fact I cannot show them using "Show expression" in the relationship editor?  The part is a sheetmetal part.  First I figured I could save a saved analysis and display the results of that analysis on the drawing.  That did not work so I saved the analysis as an analysis feature (shown below) and deleted the saved analysis.  I simply want to display the length, width and height of a sheetmetal part representing a carton.  At first I thought since the active model was the flat pattern that might have something to do with displaying the dimension.  So, I made the Generic active.  Does not matter what I do, I cannot get the value of the feature(s) to display.  The :12 is the session ID of the flat pattern.
Some data on the "Length" feature:
rcook
(To:Pieface)
Your parameter is named "DISTANCE", so you need to have "&distance:fid_length".
Pieface
(To:rcook)
Thank you.  I missed a step.  I like to keep both names the same for simplicity sake.
