Displaying Tolerance In a drawing
ptc-3021436
I have a complete drawing all dims are in place. Now I need to add a couple tol callout. Where do I find the tool to turn "on" the tolerance in a dimension? Thanks!
7 REPLIES 7
You need to add the config.pro option 'tol_display'. Set this to 'Yes'. When you go to properties for you dimension, the 'Tolerance Mode' drop down box should be availiable (which I assume must be greyed out for you).
EXCELLENT!!...thanks
The thing I don't like about this is that it turns on tolerances for ALL dimensions in the drawing. You also need to set tol_mode to "nominal". Then you can modify indiviual dimensions as needed. The default I believe is "limits".
Chris Benner
Autodesk ® Expert Elite
Oh yeah, I remember that one. When I first added tol_display, all my dimensions had tolerances on. It was a case of 'yeah thats what I want, but not realy'. Need to set tol_mode also to nominal as above.
Yup, gotit thanks!
Dale_Rosema
(To:CBenner)
What if the tol_dispaly = yes
and tol_mode = nominal
and the area to pick these is still greyed out.
Then what?
Dale_Rosema
(To:Dale_Rosema)
I found out from someone that I needed to set my tol_display to yes in the drawing options.
