Distance between point and curve geomitems
sergio72
Hello everybody, i need the distance between two geomitems, i know
that for that purpose there is a function called ProGeomitemDistanceEval
that could give me the distance between two geomitems, but in the help
documentation there is a note that says that can be measured only
following objects types: point, axis and planar surface, and what i need
is the distance between a point and a curve. Anyone know how to get the
distance between geomitems of type point and curve?. Thanks in advance.
ProSelection p_selection1
/* (In)
The first item. This can be a point, axis, or planar surface.
ProSelection p_selection2
/* (In)
The second item. This can be a point, axis, or planar surface.
double* p_result
/* (Out)
The resulting distance between the two items.
0 REPLIES 0
