Hi All,
I have a multiple sheet drawing. On the first sheet, I have the GTOL for the manufacturing side. On the last sheet, I want to show the same GTOL for the inspection side. I cannot get the GTOLs to show up on the last sheet using the Show/Erase function. The views on both sheets are using the same model and REP. The only difference is that the first sheet has a section view. Is there any way to get them to show up on both drawings without creating them twice?
WF 4.0 M100
Jody
Thank you to Bill Samuels, who sent me the following reply:
Create an offset note, list the &g# in it (use info switch dims to get the g number).It will track with the original feature control frame and always track position to the inspection dim.It worked great.
Jody
