Does Pro/E support welding
RickGiguere
Lets say you want to weld two pieces of a part together, or an assembly of parts.
I don't see a weld feature anywhere, how do you weld things together.
thanx
Rick
6 REPLIES 6
Never mind I found a link, looks like it's a separate module, and shows up when there is an assembly open.
I guess you can't weld in part mode.
I see this is an old entry, but just for the record, in Wildfire 5 you can create weld features in PART mode. I attached a screen snapshot of a simple example of a v-groove weld on a tube. That was a new function that was added in WF5.
Hi Rick,
This datasheet gives you an overview of the functionality included in each Pro/ENGINEER package: http://www.ptc.com/WCMS/files/46130/en/5437_ProE_Bro_EN.pdf
Weld modeling and documentation is included in Pro/ENGINEER Wildfire 5.0 Foundation XE.
Hope this helps!
Bettina
linda
(To:BettinaGiemsa)
open the assembly with the components to welded together, application/welding
I have several engineers that like to design welded components as a single unit and would like to put welds in, but as you stated it does not work. That is a fun idea, but in the end I think it makes a better design to have each part created individually like you would create the actual part.
you can weld a part (as seams on a sheetmetal part).  It simply needs to be added to an assembly
Bart Brejcha
Design-engine.com
