Does anyone have examples of using arrays in SmartAssembly. I am struggling with the admin guide examples.
rschoenhals
2-Explorer
I do not understand why the DELETE_ARRAY_ELEM won't work....
                SEARCH_DRW_VIEWS CurrentDrawing "*" "*" ViewArray
                DECLARE_VARIABLE INTEGER DeleteIndex 0
                FOR EachView REF ARRAY ViewArray
                                GET_DRW_VIEW_ORIENTATION EachView ViewOrientation
                                PRINT "before_EachView = % ViewOrientation = %" EachView ViewOrientation
                END_FOR
                !@@@ error checking for background and overlay views....
                                IF ViewOrientation == "UNKNOWN"
                                                DELETE_ARRAY_ELEM ViewArray DeleteIndex
                                END_IF
                                DeleteIndex++
                END_FOR
                                PRINT "after_EachView = %  ViewOrientation = %" EachView ViewOrientation
                END_FOR
4 REPLIES 4
TomU
(To:rschoenhals)
I think as soon as you execute DELETE_ARRAY_ELEM, the number of elements will shift and your DeleteIndex will no longer agree with the current array element.
TomU
(To:TomU)
Actually, I don't think that's it.  It looks like you cannot use DELETE_ARRAY_ELEM when inside a FOR loop that is processing that same array.  Here is the sample code I used to test this:
DECLARE_ARRAY TEST_ARRAY
ADD_ARRAY_ELEM TEST_ARRAY 0
ADD_ARRAY_ELEM TEST_ARRAY 1
ADD_ARRAY_ELEM TEST_ARRAY 2
ADD_ARRAY_ELEM TEST_ARRAY 3
ADD_ARRAY_ELEM TEST_ARRAY 4
FOR EACH_ELEM REF ARRAY TEST_ARRAY
  PRINT "Loop 1 Value: %, Index Value: %" EACH_ELEM DeleteIndex
  IF EACH_ELEM == "1" OR EACH_ELEM == "3"
   DELETE_ARRAY_ELEM TEST_ARRAY DeleteIndex
  END_IF
  DeleteIndex ++
END_FOR
  PRINT "Loop 2 Value: %" EACH_ELEM
END_FOR
DELETE_ARRAY_ELEM TEST_ARRAY 3
  PRINT "Loop 3 Value: %" EACH_ELEM
END_FOR
TomU
(To:TomU)
Correction.  It does work fine.  I was checking for a string instead of an integer. (Thanks to Hatim from Sigmaxim.)  The compare line should say:
  IF EACH_ELEM == 1 OR EACH_ELEM == 3
Also, removing a array element instantly changes the array size, so you need to decrement the DeleteIndex variable accordingly:
    DeleteIndex = DeleteIndex - 1
END_IF
Final code:
BEGIN_ASM_DESCR
  BEGIN_CATCH_ERROR
        END_IF
        DeleteIndex ++
    END_FOR
    END_FOR
    DELETE_ARRAY_ELEM TEST_ARRAY 1
    END_FOR
  END_CATCH_ERROR
END_ASM_DESCR
rschoenhals
2-Explorer
(To:TomU)
I believe the (DeleteIndex – 1) approach would not work on the first one you delete and if you skipped two or more without deleting.  Too be safe I took the following approach and made a temporary array of “keepers” then I clear out the original array and put the “keepers” in it.
It seems strange there isn’t a more robust way to remove elements of an array though.
Thanks for the discussion, your approach did help me get to what I needed to do.  Take care.
BEGIN_ASM_DESCR
                DECLARE_ARRAY arrayOriginal
                DECLARE_ARRAY arrayKeepers
                ADD_ARRAY_ELEM arrayOriginal "dog"
                ADD_ARRAY_ELEM arrayOriginal "cat"
                ADD_ARRAY_ELEM arrayOriginal "mouse"
                ADD_ARRAY_ELEM arrayOriginal "fish"
                ADD_ARRAY_ELEM arrayOriginal "frog"
                FOR eachOriginal REF ARRAY arrayOriginal
                                PRINT "before    eachOriginal = %" eachOriginal
                END_FOR
                                PRINT "eachOriginal = %," eachOriginal
                                IF eachOriginal == "fish" or eachOriginal == "mouse"
                                ELSE
                                                ADD_ARRAY_ELEM arrayKeepers eachOriginal
                                END_IF
                END_FOR
                CLEAR_ARRAY arrayOriginal
                FOR eachKeeper REF ARRAY arrayKeepers
                                PRINT "after                               eachKeeper = %" eachKeeper
                                ADD_ARRAY_ELEM arrayOriginal eachKeeper
                END_FOR
                                PRINT "after                               eachOriginal = %" eachOriginal
                END_FOR
END_ASM_DESCR
