Doubt regarding the sheet metal bend and unbend
Satyendra
7-Bedrock
1. Do transitions work for angle bend in sheet metal design? I can use transitions for roll bend, but I don't have much of an idea about angle bend. Does anybody have a help file regarding this?
2. What is the Distinct Areas In sheet metal unbend? Any help file will be appreciated.
Hello @Satyendra,
Thank you for using PTC Community.
Your question has not received a response so far.
In order to receive meaningful responses from other community members, could you please provide more details and context regarding your inquiry? Specifically:
  1. Could you share a screenshot or example of the angle bend you're working with? That might help clarify how transitions are behaving.
  2. Which version of Creo Sheet Metal are you using?
  3. What kind of transition are you expecting
This will enhance the likelihood of receiving valuable assistance from other Community members.
You might also find it useful to refer to this informative video on how to ask a good question.
Additionally. I'm also responding to bring attention to your question. Hopefully, another community member will be able to assist you soon.
Best Regards,
Vivek N
Community Moderation Team.
Hello Vivek,
Thank you for your response.
Actually, I have been working with sheet metal for a considerable amount of time. However, I've never used the two options, which are Transition in Angle Bend and distinct areas in Unbend.
I found a couple of helpful videos on YouTube related to the Transition in Roll Bend. But there is nothing related to these two options that I have mentioned earlier.
I'm just trying to understand these two options with a suitable example so that I can use them wherever I need.
That's all I have to say. Any help regarding this will be appreciated.
Thank you
