Hi
I can't Downloading Models for the Tutorial the 3D model for training. Does anyone could send me this model?
When I click on the link, it sends me to another page where I can`t find the download button.
I did go through many of the 4.0 tutorials back in 2019 when I had some extra time. Here is a link to my copy of the 4.0 fundamentals ZIP.
I don't know anything about that specific set of files.
You can access free tutorials at https://learningconnector.ptc.com/discovery and then click tutorials
Hi Stephen
This link sends me to the same page that I was using in the training tutorial. In this page I can`t find the download.
I am following the training of the link bellow.
I don't know. The link is from Creo 4, which is several years old.
There are tutorials available on the learning connector that don't require downloads.
OK. The company that I work uses the CREO 4 at this moment. I am work in the training for the new stuffs and I would like to follow the PTC training because of this I will need the 3D models from these parts.
Good luck. Maybe someone from PTC will be able to help you find the models.
Could you send me a link for these tutorials?
https://learningconnector.ptc.com/search/tutorials
You'll have to register for a PTC Learning Connector sign in. The tutorials are free.
I looked at a tutorial in the Learning Connector for creating holes and there is no download listed, only the steps to create the holes.
From another thread, PTC has said they do not provide training files anymore. They expect you to create your own 'base' for following the training instructions and video.
Thanks @BenLoosli . the tutorial that I am using is little bit old CREO 4.0. Maybe I can create my own "base".
Thanks for sharing @kdirth. There are a lot of models that I can use for my training. But the model crankshaft.prt is little bit different.
I think it is possible to use it.
Thanks again.
