Draft a wrapped sketch around cylinder
- 5 replies
- 4546 views
- Translate All
I have a tool path that is cut out or a cylinder. The tool path is around the cylinder. I know that I can use relations to have it wrapped proportionally around the cylinder, but I want to create drafting feature that can show the dimensions by angular dimensions. With the first angle being 15 degrees and the total length as 360 degrees.
I need some help from a Creo expert who might be able to help.
Cameron
