Draft angle default value
Abhinand
Hai all,
Please let me know how to change the default draft angle value in part modeling.By default it will be 1.00°, I want to change it to 0.50°. I know it will be somewhere in config file but not able to locate.
3 REPLIES 3
KenFarley
(To:Abhinand)
To the best of my knowledge, there is no setting for the default draft angle.
If you feel the need to have a predefined value in there, you might be able to make a mapkey that invokes the draft command? I'm not sure as whenever I'm using the draft feature I'm applying a specific angle pertinent to the design at hand, not according to best practices, like one would use for molded plastic parts, etc.
Abhinand
(To:KenFarley)
Dear KenFarley,
Thanks for the feed back. Yes map key is a option, but I have enough map keys already in use.in this case I will live with changing the draft angles each time.
Hugo-KTM
(To:Abhinand)
I added a Product Idea for that.
