Drafted Hole as Datum using GD&T Advisor
sam7088
I'm currently using Creo 9. I'm trying to make a drafted Hole as Datum B using GD&T Advisor. First, it only gives options to add Datum Targets as "Targets" tab turns red (see Image 1). After going in to the Target tab, I'm able to select "User-Defined Axis" option and then select the axis of the said hole. However, this option doesn't allow me to use position/perpendicular geometric characteristic for tolerance. The only available options are Straightness, Circularity, Profile of Surface & Angularity (see Image 2).
I'm looking for a right way to add a position/perpendicularity tolerance w.r.t Datum A (bottom surface of the block).
Hi @sam7088,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
