Dear all,
I have upgraded creo from 4th version to 5th version. The problem is when I open any drawing in creo5 the format outer box has automatically get blank rest all other title box and detail tables are available. Kindly check from attachment.
you have to configure Creo5 to see format files (.frm). Check Creo 4 config.pro file - look for PRO_FORMAT_DIR option.
Dear Martin,
Thanks, it is working now.
Simply select format directory in configure. file and save.
