Drawing Management by Projects
lchavarria
11-Garnet
I am new with Creo Schematic and I am trying to understand if there is a way to manage drawings by Project inside CREO Schematic without using Windchill, a kind of project manager where you can administrate all drawings needed to a specific project regardlees where the file are located and all this in a centralized location.
We need a centralized location in order to accomplish task like automatic cable numbering (secuencial or by location in the drawing template) along all the drawings in the project, automatic sheetset numbering of all the drawings.
I will appreciate very much your feedback
gkoch
(To:lchavarria)
Hello Luis,
I suspect this is related or approximately the same question as in your other post http://communities.ptc.com/thread/57372?tstart=0, right?
And you are not looking for another tool to replace Windchill, but for a "small solution", a mechanism inside Creo Schematics to handle files that belong together?
Anyone to have an idea or able to confirm availability yes/no?
Gunter
