Drawing Overlays
CoreyJones
3-Visitor
Drawing Overlays
Does anyone have any experience/comments on using drawing overlays in a WC system to combine large drawings (>100 pgs)?
Corey L. Jones
Design Engineering Systems Specialist
Principal Engineering Technology Development Group
ESC - Team QNA
SGT Inc.
Kennedy Space Center, FL 32899
NOTICE . . . The information contained in this communication may be sensitive, proprietary, legally privileged and/or subject to U.S. export control laws, is intended only for the use of the recipient named above. You agree to comply strictly with all U.S. export laws and assume sole responsibility for obtaining licenses to export or re-export as may be required. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication, or any of its contents, is strictly prohibited. If you have received this communication in error, please re-send this communication to the sender and delete the original message and any copy of it.
20 REPLIES 20
From Creo Parametric Help
About Using Drawing Overlays
Using overlays, you can superimpose selected views or an entire sheet of one drawing over the current drawing sheet. This functionality is available for drawings, layouts, reports, and diagrams; each can reference objects of these four types, as well as formats.
When working with overlays, remember the following points:
Overlays are read-only in the current drawing.
The system updates overlays to changes in the source drawing.
Overlaid views appear with all detail items.
You cannot select overlays for any drawing procedure.
If the size of the current drawing is different from the size of the source drawing, the overlays brought into the current drawing maintain the same screen size (that is, they occupy the same portion of the graphics window) as they had in the source drawing.
[cid:image001.png@01CF7A8A.75C53E10]
Corey L. Jones
ESC - Team QNA
SGT Inc.
This would be a great tool if you could "overlay" revisions in Windchill...or can you?
If you have the MCAD upgrade for CREO View for Windchill, then you have the ability to compare drawings and models.
Brian Toussaint
Systems Administrator
Hoshizaki America, Inc.
"A Superior Degree Of Reliability"
618 Hwy. 74 S., Peachtree City, GA 30269
Can you expand on how to do this? I have MCAD but when I use "Compare to" my fly out is empty. Thanks!
When you select Drawing #1 in the Viewables navigator, do you see the option to "Compare With"?
Madhavi
vizpundit.com
I select both using <ctrl> and then right click.
[Description: C:\Users\BTOUSS~1\AppData\Local\Temp\SNAGHTML9ef8ff3.PNG]
Brian Toussaint
It's takes a bit to dig out of the documentation how to use, but Drawing Overlay is one of the absolutely essential tools in the system.
We require all checks to be done using it - have done so far 12 years now, going back to Intralink 3.x and separate Division ProductView.
Important - Only available if you publish to PLT still I think, not if you publish to PDF. This was our overwhelming reason to use PLT instead of PDF some years back; not sure if still true but expect so.
Correct it doesn't do PDFs. That's on 10.1, doubt that it changes for 10.2.
Brian Toussaint
No change in 10.2. PDF compare was in my backlog for support in a future
release (before I left PTC couple months ago).
Hopefully, PDF compare will be supported in the next release..
Madhavi
I am aware of the functionality of Creo View to compare 2d drawings (I am the TC Chair for Visualization). My design organization would like to create drawings by using the Creo Parametric function of "Overlay" . These drawings would be considered released engineering when completed, however I am concerned this may cause relationship/reference issues in WC. It looks like Creo Parametric overlay function has been utilized very sparsely.
Corey L. Jones
ESC - Team QNA
SGT Inc.
So since we publish in PDF's I cannot use the overlay function in Creo View MCAD? It can't compare .drw files?
Can you manually publish a file to a PLT?
Is it possible to publish both PDF & PLT? Unfortunately we have processes that rely on the PDF.
The "compare" would be a very very valuable tool! Thanks everyone for any assistance or suggestions you can give.
I got it to work finally! I didn't click on the highlighted icon below as Brian pointed out. Thanks, this is great news!
(BTW .drw files opened in CreoView are disaplyed as PLT files. My error)
rreifsnyder
(To:CoreyJones)
The compare function works on .pvz files you can "Save a Copy" as.
Rob Reifsnyder
Mechanical Design Engineer/ Producibility Engineer / Components Engineer / Pro/E SME / Pro/E Librarian
[LM_Logo_Tag_RGB_NoR_r06]
If you need to do a compare ..
What has worked well for me, and requires little effort in finding unexpected changes, is to overlay a version of the new onto the old images; opening PDFs with Photoshop or Photoshop Elements. I make the new version image solid green with a 40% transparency***, the old version solid red with 60% transparency, and a background layer solid black. Every pixel that matches is yellow; non-matching new stuff is green; non-matching old is red****. A-size to J-size, takes the same time to overlay. Typical comparison is done at 200 dpi.
Anything that doesn't match needs an explanation.
It can be saved as a PDF; as many versions of the drawing can be added as you have memory for the layers, so that an entire drawing check history can be kept. And the results can be stored and reviewed using Adobe Reader, so those without special software can access the result.
Using this method has one down-side. It creates a dislike for users who nudge things all the time. Nudge a balloon, a dimension, views, notes; A good nudger will make it look like the entire drawing has changed when they haven't changed anything. It's the sort of thing ink-on-mylar drafters would never do, but some mouse users feel a compulsion. Sigh.
For those out there like us who only have Creo View Lite which comes without the compare function you can compare two drawing versions with the following technique (We have Creo View set up to publish .plt's).
The first snag you'll run into is that Windchill only allows only one Creo View window open at a time so a Save-As on each version must be done first:
1. Locate the drawing and select the desired version using History > Iteration
2. Open its representation in Creo View and Save As a PVZ
3. Locate the version you wish to compare against, open its rep, and repeat the Save As process
Now use the following technique to flip back and forth rapidly between two iterations of a drawing so that differences become very apparent:
1. Open the two saved PVZ's and maximize the two Creo View windows so there are overlaid
2. Set the zoom in each window so they exactly match - For best results use Zoom All, Fit Width, or Fit Height
3. Now to flip from one window to the other hold down the Alt key and while it is down press the Tab key - Release the Alt key and repeat the preceding to flip back to the first window.
With a little practice you can switch back and forth quickly enough to see even minute changes.
Mike Foster
ATK
StephenW
(To:CoreyJones)
If you go back and read the original post, this was never a question about doing a compare in Creo or Creo View.
Does anyone use the "OVERLAY" function in Creo to create drawings? If so, what do you use them for? Large Assy drawing? How do the references work in PDMLink?
This is of interest to my group also.
We needed to go with .pdf for our output. We looked at overlay capabilities, with a thread here last year about comparing two .pdfs to see what the difference is.
Here's what I learned then:
1. You can compare two .pdfs by opening up two sessions of Acrobat (one for each drawing). Maximize each screen, and by selecting either the CTRL or ALT key (I forget which one), you can "cycle" the view back and forth between each drawing quickly, and you can easily see the differences in both drawings.
2. Or you purchase Bluebeam Software. www.bluebeam.com . They have a CAD extension. Bluebeam compares two .pdfs in two different ways: the first is that it "overlays" both .pdfs on top of each other (in different colors). You can easily see the differences by looking at the different colors. YOu can save out as .pdf for proof of checking.
Or, you can show the differences by "balloon", where the software will draw a balloon cloud around areas of the drawing that has changed.
The software compares pixels, and if it sees something has moved, it registers it. It doesn't cost more than Adobe Pro, but has far better functionality.
- Randy Mees
All views my own, and do not reflect views of Edwards Lifesciences.
A.DelNegro
(To:CoreyJones)
Steve,
I had never heard of them but as I was thinking about it, I wonder if it could be applied to the topic I posted about multi-sheet drawings. I for one prefer a drawing for every part. The biggest drawback to that is when I want to print a set of drawings. It would seem you could create an 'assembly' of drawings that has an overlay of each of your part drawings on a different sheet. This way, when you wanted to print a full set of drawings, you could simply open the overlay drawing and print all the sheets. Hmmmm... not sure if it would be worth the effort, but maybe it would.
T
I suppose lack of familiarity with it is the lack of seeing a need for it; lack of imagination rather than lack of intrinsic value. 99.9% of users would understand overlay as a way to compare drawings. Perhaps if PTC called it drawing UDF or live embed?
I can see a minor reason why Drawing Overlay isn't often used, in bold - from http://www.mcadcentral.com/creo-tips-tricks-drawing/7042-copy-drawing-into-another-drawing.html (apparently copied from PTC Help)
When working with overlays, keep in mind the following:
?Overlays are read-only in the current drawing.
?The system updates overlays to changes in the source drawing.
?Overlaid views appear with all detail items.
?You cannot select overlays for any drawing procedure.
?If the size of the current drawing is different from the size of the source drawing, the overlays brought into the current drawing maintain the same screen size (that is, they occupy the same portion of the graphics window) as they had in the source drawing. <- this is the part that would slow people down. Why does PTC perform so many operations in drawings as based on a ratio to drawing or view size when users view drawing operations in absolute size?
It doesn't look like there's any insurmountable problem, though the same question in the Windchill section may turn up some differing opinion for data management. Is the Windchill TC any help? I guess it depends on whether the Windchill guys paid enough attention.
These are some results I found for "drawing overlay" here.
http://portal.ptcuser.org/p/fo/st/topic=3&post=27744#p27744 Detail splines wander about in Overlay
http://portal.ptcuser.org/p/fo/st/topic=24&post=19487#p19487 Weblink, JLink, Toolkit don't add Overlays
http://portal.ptcuser.org/p/fo/st/topic=3&post=56280#p56280 Font changes for no reason
http://portal.ptcuser.org/p/fo/st/topic=14&post=99936#p99936 RSD & Creo no longer overlay together
http://portal.ptcuser.org/p/fo/st/topic=24&post=18252#p18252 Drawing overlay scale problem
http://portal.ptcuser.org/p/fo/st/topic=3&post=29058#p29058 Drawing overlay scale problem
x
Sorry - didn't notice you'd posted the Overlay help; on the website the text of your help posting is spread over about 200 vertical lines; about 3 screens high, so I didn't recognize it until later.
x
