Drawing Pen line weight
amritsingh
Dear all,
As I am a creo user, I facing a problem with Pen line weight. My drawing units are in MM. But I am unable to set line weight in a decimal place like 0.5 or 0.19 like Auto Cad. What I am getting that dimension line and center line and another reference lines are coming with the same thickness. I have attached the one screenshot of the same. Kindly suggest me how I can set thickness os all lines while working in MM units
StephenW
(To:amritsingh)
You'll want to set up a pen table file.
See these posts:
https://community.ptc.com/t5/Data-Exchange/Separate-Pen-Tables-Used-for-PDF-s-and-Plot-Files/m-p/536254
https://community.ptc.com/t5/Data-Exchange/PDF-Thickness-Pen-Table/m-p/398264
There are many other posts discussing this, use the search term pen table
amritsingh
(To:StephenW)
Thanks, Stephen Williams but the problem is of the decimal place. Kindly check the attachment
Read the second link again. It describes how to use a pen table and how to set pen widths with a unit designation (only IN and CM are allowed). There's also a link to the Creo help page on pen tables.
LinkedIn
