Drawing Table Repeat Region(BOM) releations
msstocki
Is there a method of accessing the drawing number within the relations area of the table(repeat region).  I would like to use the drawing number for conditional test to format the repeat region output a certain way if conditions are met.
Marlon
4 REPLIES 4
BenLoosli
23-Emerald II
(To:msstocki)
What do mean by 'format the repeat region'?
You cannot add or remove columns from the table based on certain parameters. The table is a fixed design. You can hide rows of data for certain part numbers based on its value.
StephenW
(To:msstocki)
Repeat regions are driven by the assembly and their components (mostly parameters). Assemblies and parts don't track have anything that refers to a drawing within them.  Unless your drawing number is a parameter from within your parts or assembly, I don't think you would be able to use that.
Hi @msstocki,
Anurag
msstocki
(To:anursingh)
No resolution yet
