Hi all,
Is possible to have in drawing a parameter which can have as value the path of drawing file and be able to update when the file is moved to another location ?
Thank you!
Nope. Sorry. Here is the official statement from PTC: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS56763
Hi Tom,
I already read this case. I hope someone to have a solution using some scripts ( VB, Java,..).
Thank'you
